[postgis-tickets] [PostGIS] #2275: configure is not backwad compatible
PostGIS trac at osgeo.org
Mon Apr 22 06:23:53 PDT 2013
 Reporter:  robe                   |       Owner:  pramsey
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Note from mark_wanner
 markus_wanner:  A little background: part of why I requested to change
 PGCONFIG to PG_CONFIG was that other PGXN tools use the later env var. And
 I tried to build postgis with setting that - and failed. I don't care that
 much about the --with-*config argument, just changed it to match.
 I vote for changing the .configure back to --with-pgconfig
 so its consistent with --with-gdalconfig and friends.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2275#comment:8>
