[postgis-tickets] [PostGIS] #2279: Can't upgrade PostGIS from 2.0 (was: Can't upgrade PostGIS from 2.0 with extension)
PostGIS trac at osgeo.org
Tue Apr 23 21:02:02 PDT 2013
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 This is now SUPER SERIOUS.  To rule out extension as the culprit, I
 decided to install and upgrade the old-fashioned strk way.
 1) Create a new database and run the numerous scripts to install 2.0.3
 (both postgis.sql and rtpostgis.sql)
 2) then try to run our postgis_upgrade_20_21.sql
 and to my dismay -- I got the same error, was slightly more informative
 ERROR:  cannot drop function
 geometry_gist_sel_2d(internal,oid,internal,integer) because other objects
 depend on it
 DETAIL:  operator &&(geometry,geometry) depends on function
 operator class gist_geometry_ops_2d for access method gist depends on
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 ********** Error **********
 depend on it
 SQL state: 2BP01
 Detail: operator &&(geometry,geometry) depends on function
 Hint: Use DROP ... CASCADE to drop the dependent objects too.
 HELP pramsey.
 Even worse my old db where I had replaced binaries had to swap back
 because it literally broke all my mapping apps since && is so critical.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2279#comment:3>
