[postgis-tickets] [PostGIS] #2282: nd_stats_to_grid missing in debug build
PostGIS trac at osgeo.org
Wed Apr 24 13:00:22 PDT 2013
 Reporter:  alvherre  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:
Component:  postgis   |     Version:  trunk
 Keywords:            |
 It seems that in rev. 11289, the nd_stats_to_grid function was commented
 out.  However, this function is still used in
 compute_gserialized_stats_mode() within a POSTGIS_DEBUGF() call.  Hence,
 the build is broken when debugging is enabled:
 ERROR:  could not load library  "/home/alvherre/Code/postgis/regress/00
 -regress-install/lib/postgis-2.1.so":
 /home/alvherre/Code/postgis/regress/00-regress-install/lib/postgis-2.1.so:
 undefined symbol: nd_stats_to_grid
 This was confirmed by dustymugs in the IRC channel.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2282>
