[postgis-tickets] [PostGIS] #2285: standardize_address should no longer be marked as SETOF
PostGIS trac at osgeo.org
Fri Apr 26 03:31:54 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 While you are at it you should put a cost on these functions otherwise
 they default to 1 for C functions which isn't good as they would be more
 likely to be recomputed in cases where the planner has a choice.
 I would say a cost of 100 or 200 would be good to start.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2285#comment:1>
