[postgis-tickets] [PostGIS] #2289: Redesign Geocoder
PostGIS trac at osgeo.org
Fri Apr 26 06:19:25 PDT 2013
 Reporter:  woodbri         |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Future
Component:  tiger geocoder  |     Version:  2.0.x
 Keywords:                  |
Comment(by woodbri):
 I have 756,778 segments in stdaddr and 757,766 in tiger for MA. The
 difference is 1000+ that did not standardize. I simple left join and
 distinct on the name will show you the records that need to be considered
 when updating the the lexicon and/or rules.
 I store my tiger records as single-sided denormalized records. So if a
 segment has 4 names and 3 alt address ranges, and 2 placenames, I have
 4*3*2 records for it. Each of my tiger records has a side field so I can I
 can offset if needed. My goal was to preprocess the data to make the
 geocoder design simple and straight forward.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2289#comment:2>
