[postgis-tickets] [PostGIS] #2198: ST_Tile errors with outdb non-georeferenced
PostGIS trac at osgeo.org
Mon Feb 4 05:52:12 PST 2013
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.0
Component:  raster  |     Version:  trunk
 Keywords:          |
 It says from the docs that ST_Tile when working with outdb creates outdb.
 Not quite sure what exactly that means.  I'm getting an error trying to
 use it
 This doesn't work
 SELECT ST_Tile(rast,512,384) FROM (SELECT rast FROM
 scratch.inspection_photos_outdb WHERE filename='PHOTO_1_0001.jpg') As foo
 Gives error:
 rt_raster_add_band: Can't add a 1024x768 band to a 512x384 raster
 However the same set of non-georeference rasters in the database
 works just dandy
 SELECT ST_Tile(rast,512,384) FROM (SELECT filename, rast FROM
 scratch.old_inspection_photos_local WHERE filename='PHOTO_1_0001.jpg') As
 foo ;
 haven't tried with georeferenced outdb to see if that makes a difference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2198>
