[postgis-tickets] [PostGIS] #2196: ST_Intersects performs worse on 2.0 than 1.5
PostGIS trac at osgeo.org
Fri Feb 8 11:56:01 PST 2013
 Reporter:  zwerner  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.3
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 zwerner,
 The script worked fine for me.  Not sure about Paul, but I didn't get a
 chance to setup on 8.4 to do a compare and also a 9.2 with 1.5.  The issue
 that makes this tricky is that 9.2 has changed a lot too.  So not sure if
 the issue you are having is related to 9.2 or 2.0.
 For example on the geocode logic I have I had to revise some of my queries
 to work efficiently on 9.2 and at the time I ruled out 2.0 as the issue
 since I had 2.0 running on 8.4 and it worked faster.
 If you are able of installing 2.0 on 8.4 or 1.5 on 9.2 that would of
 course help comparing apples with apples.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2196#comment:7>
