[postgis-tickets] [PostGIS] #2202: No option to disable json-c lookup by ./configure
PostGIS trac at osgeo.org
Fri Feb 15 10:07:50 PST 2013
 Reporter:  mloskot                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.3
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:  jsonc                  |
 ./configure provides only one option to control searching of json-c
 library files:
 $ ./configure --help|grep json
   --with-jsondir=PATH     specify the json-c installation directory
 Assuming json-c is optional, unlike PROJ.4 library, if one wants to build
 PostGIS without json-c support on a system with json-c library installed,
 then the ./configure always detects and adds json-c support.
 There is no option like --without-jsonc or --disable-jsonc.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2202>
