[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Fri Feb 15 11:42:48 PST 2013
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.0
Component:  raster  |     Version:  trunk
 Keywords:          |
 This might be similar issue to what we've had before, but I get a set of
 project photos, but unfortunately all the ones exhibiting the problem are
 too big to attach.
 When I do this or ST_AsPNG
 SELECT ST_Resize(rast,0.1,0.1) FROM armory_outdb limit 1
 I get this error
 NOTICE:  The in-db representation of the out-db raster is not aligned.
 Band data may be incorrect
 CONTEXT:  PL/pgSQL function st_resize(raster,double precision,double
 precision,text,double precision) line 23 at RETURN
 ERROR:  rt_raster_from_gdal_dataset: Unable to get data from GDAL raster
 This issue doesn't happen if I load in db.
 Command I used is:
 raster2pgsql -F -Y -R C:/pics/back.jpg armory_outdb | psql -U postgres -d
 testpostgis21 -h localhost -p 5442
 POSTGIS="2.1.0SVN r11085" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" (core procs from "2.1.0SVN r11079" need upgrade) RASTER
 (raster procs from "2.1.0SVN r11079" need upgrade)
 I'll send you link in a bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203>
