[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Fri Feb 15 21:34:01 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by dustymugs):
 Are you able to run something even simpler than ST_Resize()?  Something
 like...
 SELECT ST_SummaryStats(rast) FROM armory_outdb limit 1
 All out-db rasters are handled in the exact same manner so the above
 should result in the same error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:6>
