[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Sat Feb 16 09:40:26 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by dustymugs):
 No problems found with that file using GDAL 1.10dev and latest PostGIS in
 32 and 64 bit Linux and OSX.  I think something may be wrong with your
 windows env.  Multiple versions of the same library?  Multiple GDAL
 installed?  The error with creating a temp file usually is a sign that
 either there isn't enough storage space or there is some privilege issue
 going on (lack of privileges or trying to create the temp file in the
 wrong place).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:18>
