[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Sat Feb 16 21:20:13 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by robe):
 I guess I should run against 9.1 as well to rule out PG 9.2 as culprit.
 You don't have a 9.2 instance on your Mac or Linux do you?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:27>
