[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Sun Feb 17 10:00:13 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by robe):
 I'm having trouble compiling with --enable-debug=4.  Gives error:
 rt_api.c: In function 'rt_band_load_offline_data':
 rt_api.c:1635:3: error: expected expression before ')' token
 make[2]: *** [rt_api.o] Error 1
 Though seems to be compiling if I take debug configure out.   I'll check
 the output after its' done.  Can you see if you get errors compiling with
 debug flags on.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:34>
