[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Wed Feb 20 10:22:12 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by dustymugs):
 This rabbit hole goes deep.  I'm testing with Windows 7 64-bit with
 PostgreSQL 9.2.3 from EDB and the latest PostGIS build (r11103).
 ST_SummaryStats() works fine no matter how many times I run it.
 With CPL_DEBUG=ON, I get the libjpeg error message for ST_Resize().  Since
 ALL out-db rasters are processed the exact same way (one function to rule
 them all), the error is happening on the GDAL side in the actual
 operation.
 Turning off UAC doesn't eliminate the error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:46>
