[postgis-tickets] [PostGIS] #2210: [raster]: ST_Envelope for raster that considers only data values
PostGIS trac at osgeo.org
Fri Feb 22 17:59:03 PST 2013
 Reporter:  robe         |       Owner:  dustymugs
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Comment(by robe):
 How about signature:
 ST_ConvexHull(raster rast, exclude_no_data = false, band_num=NULL);
 If band_nun is NULL then (all bands are considered as is current behavior)
 meaning the first band to hit a road block wins.
 e.g.
 Let's say you have 3 bands and for the sake of silly argument, band 1 is
 nothing but no data, but band 2 has all pixels with data, and band 3 has
 some.
 Then an ST_ConvexHull that excludes no data will return the same as
 ST_ConvexHull that includes no data -- since band 2 hits its limit first.
 In theory if there is any band that does not have a no data value you can
 return the same as current ST_ConvexHull if no bands are explicitly
 specified.
 If you specify band 3 then you get a possibly smaller rectangle than the
 original and if you specify band 1 you get an EMPTY POLYGON.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2210#comment:5>
