[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Fri Feb 22 18:12:15 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS GDAL
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Changes (by robe):
  * milestone:  PostGIS 2.1.0 => PostGIS GDAL
Comment:
 I switched to GDAL issue.  Is there anyway to test this issue on Linux or
 it just doesn't happen because GDAL writes to a place accessible by all.
 I would think like SELinux and Ubuntu would be pretty locked down on
 rights.  Though I guess this issue would never happen unless you happen to
 have a jpeg that has overviews? Which may be rare or does it have to do
 with the size of the ffile that it then switches to using disk?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:54>
