[postgis-tickets] [PostGIS] #1292: ST_SnapToGrid returns a value out of range
PostGIS trac at osgeo.org
Mon Feb 25 00:31:23 PST 2013
  Reporter:  realityexists  |       Owner:  pramsey
      Type:  patch          |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.1.0
 Component:  postgis        |     Version:  trunk
Resolution:  fixed          |    Keywords:
Changes (by realityexists):
  * status:  reopened => closed
  * resolution:  => fixed
  * milestone:  PostGIS 2.0.3 => PostGIS 2.1.0
Comment:
 Thank you! Tested r11113 and all seems to be well.
 The problem only occurred on trunk. 2.0 would have been fine. I've changed
 the Milestone on this ticket to 2.1.0 in case that caused any confusion.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1292#comment:16>
