[postgis-tickets] [PostGIS] #2214: Missing privileges requirements from Testing section
PostGIS trac at osgeo.org
Mon Feb 25 07:57:25 PST 2013
 Reporter:  mloskot        |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 The [http://postgis.net/docs/manual-dev/postgis_installation.html#id375515
 2.4.4. Testing] section does not give any hints on system and database
 user privileges required to run the tests.
 Assuming that installation from sources is performed ''not as postgres'',
 but another non-root user with sudo privileges, then it would be good to
 add a note on how to avoid common errors while running make check as non-
 root non-postgres user:
 psql: FATAL: permission denied to set parameter...
 psql: FATAL:  {Peer|Ident} authentication failed for user...
 Pointing to PGUSER and PGPASSWORD variables may be worth as well,
 with relevant md5 authentication set in pg_hba.conf.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2214>
