[postgis-tickets] [PostGIS] #2176: ST_ChangeEdgeGeom: exception on SymDifference
PostGIS trac at osgeo.org
Wed Jan 16 02:00:41 PST 2013
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.3
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 Can you provide HEXWKB please ? It's what you get by default if you
 `SELECT the_geom FROM table` from a text cursor. I don't need the utmzone
 function, just the original and simplified geometries.
 The idea is to produce a testcase that would trigger the bug in a script
 like this:
  SELECT CreateTopology('bug2176');
  SELECT TopoGeo_addLinestring('bug2176', '<first_geometry>');
  SELECT ST_ChangeEdgeGeom('bug2176', 1, '<second_geometry>');
 With the smallest possible '<first_geometry>' and '<second_geometry>'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2176#comment:5>
