[postgis-tickets] [PostGIS] #657: Spheroid/Ellipsoid projection given Lat/Lon, Distance & Bearing
PostGIS trac at osgeo.org
Fri Jan 25 03:41:16 PST 2013
  Reporter:  lwilmen  |       Owner:  pramsey
      Type:  task     |      Status:  reopened
  Priority:  low      |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  bearing distance liblwgeom spheroid ellipsoid
Changes (by michischolz):
  * priority:  critical => low
  * status:  closed => reopened
  * resolution:  fixed =>
  * type:  enhancement => task
Comment:
 Please update the documentation for ST_Project. It sais nothing about how
 to pass the azimuth and as said before, the example is still showing
 degrees instead of radians.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/657#comment:9>
