[postgis-tickets] [PostGIS] #2193: Utilize PAGC parser as drop in replacement for tiger normalizer
PostGIS trac at osgeo.org
Tue Jan 29 13:19:31 PST 2013
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Yah I was thinking that too after I made that comment that those may be
 different depending on locality and might be better packaged as separate
 extension or configuration module you load with a function in
 address_standardizer extension similar to the Full Text dictionaries to
 denote which to use.
 Then each can be packaged as an extension as you have it similar to the
 FText dictionaries here: http://pgxn.org/tag/dictionary/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2193#comment:2>
