[postgis-tickets] [PostGIS] #2193: Utilize PAGC parser as drop in replacement for tiger normalizer
PostGIS trac at osgeo.org
Tue Jan 29 15:49:15 PST 2013
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Yes makes sense. I think also as far as packaging the tables, I'll go with
 as a separate extension but perhaps call it us_support_tables since I
 think your current is optimized for that.
 BTW I just compiled under ming64 but installing the extension on my pg92
 edb build.  It doesn't seem to be crashing.  I haven't tried under mingw
 compiled pg though so might be a different story.  I'll let you know.
 Were you testing against your mingw compiled postgresql or the EDB VC++
 version.  The mingw I think my instructions are to compile with debug
 flags and so forth so may be catching things the EDB installed one isn't.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2193#comment:5>
