[postgis-tickets] [PostGIS] #2373: [raster] Performance test suite
PostGIS trac at osgeo.org
Mon Jul 1 10:26:16 PDT 2013
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS Future
Component:  raster       |     Version:  trunk
 Keywords:               |
 It would be nice to have a standardized performance test suite. This way,
 performance regressions can be caught quickly.
 A possible sample dataset is the dataset from
 [http://www.grassbook.org/data_menu3rd.php Open Source GIS: A GRASS GIS
 Approach]. The dataset itself would not be the code repo but rather pulled
 from the server on the first run and updated if need be.
 The tests should be realistic to what an end user would do with the data
 (or maybe what the exercises in the book does).
 Performance numbers from the test suite will only be applicable to the
 local computer running the suite and only if the suite is run at least
 once to establish baseline values.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2373>
