[postgis-tickets] [PostGIS] #2372: KML with space around ordinate values considered invalid
PostGIS trac at osgeo.org
Mon Jul 1 14:03:46 PDT 2013
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 1.5.9
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  history, kml
Comment(by colivier):
 Humm i've replyied a bit too fast on my latest post:
 After checking back in OGC KML 2.2 spec,
 it itself contains some examples (e.g in 9.10.4)
 allowing space before/after tuples,
 or also several spaces as a tuple separator
 So explain why 1,2,5 use cases were previously allowed,
 in first coordinates parser implementation.
 So mean NOTICE only on 3 and 4 uses cases.
 I've give a look on latest trunk
 Here an enhanced version of coordinates regress/in_kml.sql
 who should reflect current discussion:
 -- Coordinates
 -- X,Y
 SELECT 'coordinates_1',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2</kml:coordinates></kml:Point>'));
 -- ERROR: single X
 SELECT 'coordinates_2',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1</kml:coordinates></kml:Point>'));
 -- X,Y,Z
 SELECT 'coordinates_3',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2,3</kml:coordinates></kml:Point>'));
 -- ERROR: 4 dimension
 SELECT 'coordinates_4',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2,3,4</kml:coordinates></kml:Point>'));
 -- ERROR: Only commas
 SELECT 'coordinates_5',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>,</kml:coordinates></kml:Point>'));
 SELECT 'coordinates_6',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates> ,
 -- ERROR: empty or spaces
 SELECT 'coordinates_7',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates></kml:coordinates></kml:Point>'));
 SELECT 'coordinates_8',
 -- ERROR: End on comma
 SELECT 'coordinates_9',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2,3,</kml:coordinates></kml:Point>'));
 SELECT 'coordinates_10',
 ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2,</kml:coordinates></kml:Point>'));
 -- ERROR: Begin on comma
 SELECT 'coordinates_11',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>,1
 2,3</kml:coordinates></kml:LineString>'));
 -- Whitespaces before and after
 SELECT 'coordinates_12',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates> 1,2 3,4
 SELECT 'coordinates_13',
        1,2 3,4
 -- NOTICE: Spaces insides -- Cf #2372
 SELECT 'coordinates_14',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>1, 2
 3,4</kml:coordinates></kml:LineString>'));
 SELECT 'coordinates_15',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>1,2 3
 SELECT 'coordinates_16',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>1,2, 3 4,
 5,6</kml:coordinates></kml:LineString>'));
 -- Several spaces as tuples separator
 SELECT 'coordinates_17',
 SELECT 'coordinates_18',
 1,2
 3,4
 -- ERROR: Mixed dimension
 SELECT 'coordinates_19',
 3,4,5</kml:coordinates></kml:LineString>'));
 SELECT 'coordinates_20',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>1,2,3
 SELECT 'coordinates_21',
 SELECT 'coordinates_22',
 SELECT 'coordinates_23',
 SELECT 'coordinates_24',
 -- ERROR: Mixed dimension and extra tuple separator (Cf #2372)
 SELECT 'coordinates_25',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>1,2 3,4,
 -- ERROR: Junk
 SELECT 'coordinates_26',
 ST_AsEWKT(ST_GeomFromKML('<kml:LineString><kml:coordinates>!@#$%^*()"</kml:coordinates></kml:LineString>'));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2372#comment:23>
