[postgis-tickets] [PostGIS] #2266: GEOS requirement misstated
PostGIS trac at osgeo.org
Tue Jul 2 15:19:47 PDT 2013
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.1.1
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by pramsey):
 I'm totally not seeing this. I installed a too-low geos in my system path
 (/usr/local) and installed a good geos in a custom path (/opt/geos) and
 configured with the custom location, and it worked fine.
 ./configure --with-libintl-prefix=/opt/local \
  --with-libiconv-prefix=/opt/local --with-jsondir=/opt/local \
  --with-gettext=/opt/local \
  --with-geosconfig=/opt/geos/bin/geos-config
 If I configure without the custom geos location, it fails, as it should,
 with the too-low geos.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2266#comment:9>
