[postgis-tickets] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Wed Jul 3 14:07:25 PDT 2013
  Reporter:  pierrevandelaar        |       Owner:  robe
      Type:  defect                 |      Status:  reopened
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:                         |    Keywords:
Comment(by robe):
 mstucka,
 postgisgui standalon is just for the gui, has nothing to do with this
 error.
 It's the libxml2-2.dll in the bin folder you want to replace with the
 libxml2.dll in bin folder.
 Give that a try and see if it works.
 This error notice also happens if you installed the WRONG version of
 PostGIS 2.0.3-2.  Note there are 2 of these and if you are running
 Postgres 9.2 x64 you want this installer:
 http://download.osgeo.org/postgis/windows/pg92/postgis-
 pg92x64-setup-2.0.3-2.exe or the binaries
 (http://download.osgeo.org/postgis/windows/pg92/postgis-
 pg92-binaries-2.0.3w64-2.zip).  (the non-labeled installer one is for
 32-bit ).  I'll be changing next go around to be clearer (it was just that
 32-bit was the only for a while and I didn't tack on the 32-bit when
 64-bit came along though I do on the zip)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:13>
