[postgis-tickets] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
PostGIS trac at osgeo.org
Fri Jul 5 04:53:07 PDT 2013
#1798: Performance issue with ST_Intersects(geometry,geometry)
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by strk):
 hint2: count(gid) to take off the cost of checking all attributes for
 being null.
 hint3: play with order by as that seems to be the only difference between
 the two calls to ST_Intersects, right ? (since the input table contains
 the same data)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:26>
