[postgis-tickets] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
PostGIS trac at osgeo.org
Fri Jul 5 05:05:26 PDT 2013
#1798: Performance issue with ST_Intersects(geometry,geometry)
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by robe):
 It could be maybe just because ST_DWithin doesn't have to do that geos
 serialization step that its outperforming by saving that step, but then I
 would expect ST_Intersects to gain by using prepared geometry.
 The polygons aren't that big:
 SELECT Max(ST_NPoints(geom)), AVG(ST_NPoints(geom))
 frOM intersects_order;
 Max   Avg
 582   416.5136436597110754
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:29>
