[postgis-tickets] [PostGIS] #2375: Regress check 9.3 windows builds under EDB instead of mingw
PostGIS trac at osgeo.org
Sun Jul 7 00:59:07 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  task       |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.0
Component:  buildbots  |     Version:  2.1.x
 Keywords:  mingw64    |
 The 9.3 windows builds starting with PostGIS 2.1.0 I am building with gcc
 4.8.0 (the 64-bit uses Structured Error Handling (SEH), and 32-bit still
 uses (Set Jump Long Jump) sjlj error handling (dwarf I had accidentally
 put in in my first go round and did not work (shall I say crashes since it
 can't jump VC++ dll boundaries easily).
 http://stackoverflow.com/questions/15670169/what-is-difference-between-
 sjlj-vs-dwarf-vs-seh
 Anyrate now that 9.3 w64-bit with gcc 4.8 seh regresses under EDB, I'm
 switching the 9.3 regress tests from mingw to EDB.  Have the 9.3 w32 bit
 set already.  Should have the 9.3 w64bit ready as well tomorrow ready for
 testing with upcoming 2.1.0 rc1 and 2.2.0 moving forward.
 I'm still going to keep 9.2 and 9.1 compiled under the old 4.5.4 sjlj
 chains since I don't want to rock the boat too much.  If 9.3 looks all
 good (which I expect it will barring I didn't screw anything up), I'll may
 switch the 9.2 chains in a 2.0 micro to 4.8 as well.  This has to be done
 for both 2.0 and 2.1 if I do that to prevent corrupting a 2.0 build that
 has 2.1 installed as well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2375>
