[postgis-tickets] [PostGIS] #2376: ST_MakeValid: Segmentation fault terminated by signal 11
PostGIS trac at osgeo.org
Mon Jul 8 06:32:27 PDT 2013
  Reporter:  postgistrac  |       Owner:  pramsey
      Type:  defect       |      Status:  closed
  Priority:  high         |   Milestone:  PostGIS 2.1.0
 Component:  postgis      |     Version:  2.0.x
Resolution:  duplicate    |    Keywords:  st_makevalid segmentation fault segfault
Changes (by robe):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 My install returns:
 POSTGIS="2.1.0rc1dev r11637" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel.
 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24 GDAL_DATA not
 found" LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3beta2,
 compiled by Visual C++ build 1600, 32-bit
 NOTICE:  LWGEOM_GEOS_nodeLines(): TopologyException: found non-noded
 intersection between LINESTRING (94.1104 0.0976963, 92.2292 -0.670284) and
 LINESTRING (92.2292 -0.670284, 92.2292 -28.3531) at 92.229231799999994
 -0.67028434840479534
 I think this issue has already been fixed in 2.1.0 and 2.0.4 about to be
 released in ticket #2307.  Also you are running an obsolete GEOS.  Might
 want to upgrade to GEOS 3.3.8 or 3.3.9 which will be out soon.  Or even
 GEOS 3.4.0 which will also be out soon.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2376#comment:1>
