[postgis-tickets] [PostGIS] #2379: Topology regression failure in regress/topogeo_addlinestring
PostGIS trac at osgeo.org
Sat Jul 13 13:12:48 PDT 2013
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Comment(by robe):
 pramsey you forgot to mention which GEOS you are running.  I suspect it
 might be GEOS related since there was a time when strk had regression
 logic in there that would fail unless you were running an unreleased
 version of GEOS.  I think that has all been taken out but could still be
 related.  I only test with unreleased virgin libraries :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2379#comment:3>
