[postgis-tickets] [PostGIS] #2380: Fix pagc lookup tables resolves BAY STATE incorrectly
PostGIS trac at osgeo.org
Mon Jul 15 07:30:51 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  2.1.x
 Keywords:                       |
Comment(by robe):
 adding BAY STATE entry as token 5 fixed issue.  Probably because I need
 things abbreviated, bout couldn't find a faulty record.  I'll also need to
 upper case everything to keep formatting consistent.  Will close after I
 test some more.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2380#comment:1>
