[postgis-tickets] [PostGIS] #2382: Can't install postgis extension with pgAdmin 1.18 beta 1
PostGIS trac at osgeo.org
Tue Jul 16 09:25:50 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 I'm pretty sure this is a bug in pgAdmin 1.18 beta 1 (and might be related
 to the bug I already posted that they have resolved).  Putting here for
 now since it seems to have something to do with GUC.
 I ruled out 9.3 beta as culprit since I can install extension with pgAdmin
 dialog  in pgAdmin 1.16 with no issue.
 Running
 CREATE EXTENSION postgis VERSION "2.2.0dev";
 Works fine in both pgAdmin 1.18 beta 1 and 1.16.1
 Using the extension dialog in 1.16.1 also works.
 However: usig the pgAdmin 1.18 beta 1 dialog gives this error:
 ERROR:  attempt to redefine parameter "postgis.backend"
 What pgAdmin III 1.18.beta 1 is doing beyond CREATE EXTENSION I have no
 clue.  All the above excersises are running against PostgreSQL 9.3 beta2.
 haven't tried on lower
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382>
