[postgis-tickets] [PostGIS] #2382: Can't install postgis extension with pgAdmin 1.18 beta 1
PostGIS trac at osgeo.org
Tue Jul 16 09:46:19 PDT 2013
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Okay this is even more complicated.  I started with a fresh new database,
 installed PostGIS with 2.1.0rc1 with pgAdmin 1.18 beta1 and it worked just
 dandy.
 Then I proceeded to upgrade my database to 2.2.0dev (using pgAdmin 1.18
 beta 1) GUI and ran into the error.
 It also does the same thing if I installed 2.1.0rc1  -- do a DROP
 EXTENSION cascade with the interface, and then install 2.2.0dev with the
 GUI.
 So it is possible that its not specifically a pgAdmin 1.18beta 1 bug but
 some feature of 1.18 checking GUCs or something that is catching an
 incomplete removal of postgis.backend GUC.
 Perhaps I should try the same exercise with another extension that uses
 GUCs
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:2>
