[postgis-tickets] [PostGIS] #2383: Create extension with backslash_quote off
PostGIS trac at osgeo.org
Tue Jul 16 10:21:28 PDT 2013
 Reporter:  sbranchaw  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.4
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
 Problem: backslash_quote has to be on in order to create the PostGIS
 extension.
 This is an inconvenience because I have a nightly backup job that restores
 a compressed dump file to a database where backslash_quote is turned off
 for security reasons.
 To reproduce:
 1. createdb postgis_testdb
 2. psql postgis_testdb
 3. SET backslash_quote = off;
 4. CREATE EXTENSION postgis;
 Receive the error:
 postgis_testdb=# CREATE EXTENSION postgis;
 ERROR:  unsafe use of \' in a string literal
 LINE 29:                 RAISE WARNING E'Format \'%\' is not recogniz...
 HINT:  Use '' to write quotes in strings. \' is insecure in client-only
 encodings.
 QUERY:
     DECLARE
         params text[];
         rastout raster;
     BEGIN
         IF rast IS NULL THEN
             RAISE WARNING 'Cannot set georeferencing on a null raster in
 st_setgeoreference.';
             RETURN rastout;
         END IF;
         SELECT regexp_matches(georef,
 E'(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s'
 E'(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)')
 INTO params;
         IF NOT FOUND THEN
             RAISE EXCEPTION 'st_setgeoreference requires a string with 6
 floating point values.';
         END IF;
         IF format = 'ESRI' THEN
             -- params array is now:
             -- {scalex, skewy, skewx, scaley, upperleftx, upperlefty}
             rastout := st_setscale(rast, params[1]::float8,
 params[4]::float8);
             rastout := st_setskew(rastout, params[3]::float8,
 params[2]::float8);
             rastout := st_setupperleft(rastout,
                                    params[5]::float8 - (params[1]::float8
 * 0.5),
                                    params[6]::float8 - (params[4]::float8
 * 0.5));
         ELSE
             IF format != 'GDAL' THEN
                 RAISE WARNING E'Format \'%\' is not recognized, defaulting
 to GDAL format.', format;
             END IF;
 params[4]::float8);
             rastout := st_setskew( rastout, params[3]::float8,
 params[2]::float8);
             rastout := st_setupperleft(rastout, params[5]::float8,
 params[6]::float8);
         END IF;
         RETURN rastout;
     END;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2383>
