[postgis-tickets] [PostGIS] #2384: [raster] Problem in ST_Neighborhood(raster, integer, geometry, integer, integer, boolean)
PostGIS trac at osgeo.org
Wed Jul 17 05:48:29 PDT 2013
integer, boolean)
 Reporter:  jawj     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 I've just been trying to get to grips with st_neighborhood, and I think
 there's a problem in the variant that accepts a point (alternatively, if
 I've misunderstood what's going on here, then please accept my apologies).
 In a certain query I'm getting the following error:
 ERROR:  invalid input syntax for integer: "-0.6465376"
 CONTEXT:  PL/pgSQL function "st_neighborhood" line 15 at assignment
 The problem is that the function seems to expect the x and y coordinates
 of the provided point geometry to be integers. (The PL/pgSQL source of the
 function is reproduced below for convenience).
 Firstly, I don't think there's any reason to suppose that the x and y
 coordinates of the point argument will be integers.
 Secondly, they're simply used as inputs to st_worldtorastercoordx/y, and
 those functions expect double precision input in any case.
 CREATE OR REPLACE FUNCTION public.st_neighborhood(rast raster, band
 integer, pt geometry, distancex integer, distancey integer,
 exclude_nodata_value boolean DEFAULT true)
  RETURNS double precision[]
  LANGUAGE plpgsql
  IMMUTABLE STRICT
 AS $function$
         DECLARE
                 wx int;
                 wy int;
                 rtn double precision[][];
         BEGIN
                 IF (st_geometrytype($3) != 'ST_Point') THEN
                         RAISE EXCEPTION 'Attempting to get the neighbor of
 a pixel with a non-point geometry';
                 END IF;
                 IF ST_SRID(rast) != ST_SRID(pt) THEN
                         RAISE EXCEPTION 'Raster and geometry do not have
 the same SRID';
                 END IF;
                 wx := st_x($3);
                 wy := st_y($3);
                 SELECT _st_neighborhood(
                         $1, $2,
                         st_worldtorastercoordx(rast, wx, wy),
                         st_worldtorastercoordy(rast, wx, wy),
                         $4, $5,
                         $6
                 ) INTO rtn;
                 RETURN rtn;
         END;
         $function$
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2384>
