[postgis-tickets] [PostGIS] #2385: ST_MakeLine causing out of memory error
PostGIS trac at osgeo.org
Thu Jul 18 07:47:48 PDT 2013
  Reporter:  ris      |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:  ST_MakeLine memory aggregate
Comment(by ris):
 Looking further into postgres bug 6698, it doesn't seem to have been fixed
 at all. (This investigation is not aided by postgres not having a real bug
 tracker)
 So you may well be right and this could just be the same bug. I was
 assuming that a bug reported in 9.1.2 over a year ago would have had a fix
 make its way into 9.1.9 and so this would be a similar-but-not-the-same
 bug caused by ST_MakeLine doing things based on the way array() was doing
 things and thus picking up some of its bugs. But apparently not.
 Not really sure what to do here - I might prod the postgres mailing list
 over 6698 but as this bug is surfacing in postgis it may not be welcome.
 But I feel at least the existence of this bug should be documented
 somewhere for now hence its existence here.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2385#comment:5>
