[postgis-tickets] [PostGIS] #2385: ST_MakeLine causing out of memory error
PostGIS trac at osgeo.org
Thu Jul 18 13:04:17 PDT 2013
  Reporter:  ris      |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS Future
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:  ST_MakeLine memory aggregate
Comment(by pramsey):
 Well, forming a 10M point line from 10M points can be reasonably expected
 to take about 500Mb (about 250M for each set of 10M points, and you will
 have both the line and points in memory at the time you finish). And since
 you're crossing a relation of 10m with a relation of 10 in your increased
 example, you're looking at 5Gb, which seems legitimately out of memory, no
 leaks or bad practice required.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2385#comment:11>
