[postgis-tickets] [PostGIS] #2387: Register pagc_address_standardizer as a PostgreSQL extension package
PostGIS trac at osgeo.org
Thu Jul 18 20:51:23 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  enhancement          |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.2.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
 I was also thinking since we are at a stable essentially 1.0 point and the
 address_standardizer is now wrapped as an extension and its fairly light-
 weight (only extra dependencies on pcre stuff available on most Linux/Unix
 distros), it might be worthwhile to register it as an official PostgreSQL
 extension at
 http://manager.pgxn.org/
 Thinking about it more, since it doesn't have any direct reliance on
 PostGIS, it will probably be better served if its stands on its own since
 it has value without anything else.
 The other benefit is that folks on Unix/Linux can then install it using
 the pgxn client.
 http://pgxnclient.projects.pgfoundry.org/
 Then I can amend the instructions accordingly to offer this simplified
 instruction set in PostGIS docs in additiona to hte standard svn checkout
 approach.
 Sadly this approach doesn't work on Windows cause windows doesn't really
 support PostgreSQL make files unless you are building under Mingw. (strk
 keep your mouth shut. :) )
 I'll be shipping address_standardizer with the newly dubbed (PostGIS
 bundle starting at 2.1) and update our instructions accordingly   so
 doesn't matter for windows users.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2387>
