[postgis-tickets] [PostGIS] #2144: totopoGeom have an extra arg to prevent addition of primitives to topology
PostGIS trac at osgeo.org
Fri Jul 19 15:13:08 PDT 2013
 Reporter:  robe         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  topology     |     Version:  trunk
 Keywords:  gsoc         |
Comment(by robe):
 Not entirely.  The reason is if you are throwing in a bunch of geometries
 where you've already built a topology, any creation of a new face etc,
 might imply a problem if your assumption is you have already created the
 elemental pieces.  So even as an admin you may want that safety net.  Then
 in some cases having primitive automatically created is expected and
 desired (even possibly for admins).
 I suppose you could go around changing set session_authorization and so
 forth to change your role, but that sounds like a huge hassle to me (more
 so than just adding an extra optional arg to the function)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2144#comment:6>
