[postgis-tickets] [PostGIS] #2391: TopoGeo_AddPolygon splits again on second call
PostGIS trac at osgeo.org
Sun Jul 21 09:06:44 PDT 2013
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Description changed by robe:
Old description:
> strk,
> Not sure if this is related to issue #2273 I complained about.
> I'm running this (I have the postgres.backend issue if you are wondering
> why I can't upgrade to 2.2.0dev for PostGIS part.
> POSTGIS="2.2.0dev r11710" GEOS="3.4.0dev-CAPI-1.8.0 r3846" PROJ="Rel.
> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
> LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY RASTER PostgreSQL 9.3beta2,
> compiled by Visual C++ build 1600, 64-bit
> and I tried with my PostgreSQL 9.2 64-bit install too and have the same
> issue.
> Anyway I'm puzzled by this to recreate
> run the attached ch08_staging (for the record data is the city boundary
> file from here http://www.victoria.ca/EN/main/city/open-data-
> catalogue.html)
> SELECT CreateTopology('ch08_topology',4326);
> SELECT gid, TopoGeo_AddLineString('ch08_topology', geom) As edge_id
> FROM (SELECT gid, (ST_Dump(geom)).geom
>  FROM ch08_staging.cityboundary
> ) As f;
> -- outputs --
> gid | edge_id
> 1,1
> SELECT topologysummary('ch08_topology');
> outputs:
>                   topologysummary
>  Topology ch08_topology (1), SRID 4326, precision 0+
>  1 nodes, 1 edges, 1 faces, 0 topogeoms in 0 layers+
> run the add again
> ) As f;
> Get output:
>  gid | edge_id
>    1 |       1
>    1 |       2
> Where did edge_id 2 come from.
> outputs:
>                   topologysummary
>  2 nodes, 2 edges, 1 faces, 0 topogeoms in 0 layers+
> Is this a bug or just an occupational hazard with tolerances?
> Unfortunately if I repeat the above exercise with something like
> I still get an additional split the second call.
> SELECT gid, TopoGeo_AddLineString('ch08_topology', geom, 0.0001) As
> edge_id
> ) As f;
> I've also tested on 2.1.0 and have same issue, but haven't tested on 2.0.
New description:
 strk,
 issue.
 catalogue.html)
 ) As f;
 -- outputs --
 gid | edge_id
 1,1
 outputs:
                   topologysummary
 run the add again
 ) As f;
 Get output:
  gid | edge_id
    1 |       1
    1 |       2
 outputs:
                   topologysummary
 edge_id
 ) As f;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2391#comment:1>
