[postgis-tickets] [PostGIS] #2278: make liblwgeom compatible between micro releases
PostGIS trac at osgeo.org
Sun Jun 2 09:55:51 PDT 2013
 Reporter:  mwanner      |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS Future
Component:  liblwgeom    |     Version:  2.0.x
 Keywords:               |
Comment(by robe):
 strk and while you are at it.  If you really want to make it easy for
 people to use this, it should be able to compile separately from postgis
 (not requiring you have to compile PostgreSQL first).
 I can't believe the other Sandro has to go thru this much effort to use
 it.  He must be really patient or some sort of super hero.
 http://www.gaia-gis.it/gaia-sins/mingw64_how_to.html#liblwgeom
 BTW: he has the same problem that it builds statically for him too under
 mingw64
 and others
 http://gis.stackexchange.com/questions/48495/how-to-compile-liblwgeom-
 independently
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2278#comment:8>
