[postgis-tickets] [PostGIS] #2334: Cannot upgrade from 2.0 to 2.1 (non-extension upgrade)
PostGIS trac at osgeo.org
Tue Jun 4 06:17:47 PDT 2013
 Reporter:  dustymugs  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.1.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Supposedly drop_before.sql is already included in
 postgis_upgrade_20_21.sql, according
 to this rule in Makefile:
 postgis_upgrade_20_21.sql.in: postgis_drop_before.sql postgis.sql
 postgis_drop_after.sql
   cat $^ > $@
 postgis_upgrade_20_21.sql: postgis_upgrade_20_21.sql.in
 ../utils/postgis_proc_upgrade.pl
   $(PERL) ../utils/postgis_proc_upgrade.pl $< 2.0 > $@
 Dustymugs, are you in a position to try reproducing this bug after
 checking generation of that file ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2334#comment:6>
