[postgis-tickets] [PostGIS] #876: Better document ST_Azimuth
PostGIS trac at osgeo.org
Fri Jun 7 00:46:54 PDT 2013
  Reporter:  strk           |       Owner:  robe
      Type:  task           |      Status:  reopened
  Priority:  medium         |   Milestone:  PostGIS 2.0.4
 Component:  documentation  |     Version:  trunk
Resolution:                 |    Keywords:
Comment(by strk):
 robe: you decide, you're the doc master. I'm fine as long as the "on-the-
 clock" numbers are there (they are, but the "clock" reference has been
 removed which I think makes it harder to read). I confirm the "down to up"
 part was broken in that 12 on the clock is 0, so it starts from the top,
 not the bottom...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/876#comment:10>
