[postgis-tickets] [PostGIS] #2353: [raster] GDAL's GDALFPolygonize() function
PostGIS trac at osgeo.org
Fri Jun 7 11:35:54 PDT 2013
 Reporter:  jeanm   |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS GDAL
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Comment(by dustymugs):
 So the problem is in the function GDALFloatEquals() of
 alg/fpolygonize.cpp. Specifically, aInt and bInt are integers. intDiff is
 also an integer and is assigned the value from abs(aInt - bInt). Problem
 is that the difference between aInt and bInt may exceed a 32-bit integer.
 This is evident when GDALFloatEquals() is called:
 GDALFloatEquals(4, -1)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2353#comment:3>
