[postgis-tickets] [PostGIS] #2359: raster2pgsql - large collection of examples of different bugs in -l (overviews)
PostGIS trac at osgeo.org
Thu Jun 13 02:14:12 PDT 2013
(overviews)
 Reporter:  gbell                   |       Owner:  dustymugs
     Type:  defect                  |      Status:  new
 Priority:  high                    |   Milestone:  PostGIS 2.1.0
Component:  raster                  |     Version:  2.0.x
 Keywords:  raster2pgsql overviews  |
 The big picture here is that the behaviour of the current stable version
 of raster2pgsql is unpredictable and highly prone to error (both in
 raster2pgsql and in the resulting SQL) when overview layers are specified.
 Since the raster2pgsql overview factor is specified as the log_2() of the
 scale rather than as the scale, it is very likely that users will
 encounter these bugs.
 The general theme of these errors are:
 a)  when an overview is created at too high a level, rather than generate
 a small picture, or refuse to generate the overview, raster2pgsql either
 segfaults in various ways, or its emitted SQL attempts to generate the
 overview and fails in a variety of ways, which share a theme of being
 untidy crashes.
 b) When someone tries to add a raster as a table that already exists,
 unhelpful and messy errors are caused by the generated SQL rather than a
 clean failure explaining the problem.
 >raster2pgsql
 RELEASE: 2.0.3 GDAL_VERSION=110 (r11128)
 Using some examples taken from the recommended samples at
 http://trac.osgeo.org/geotiff/:
 ftp://ftp.remotesensing.org/pub/geotiff/samples/made_up/bogota.tif
 ftp://ftp.remotesensing.org/pub/geotiff/samples/made_up/ilatlon_float.tif
 0a. Base case: both import correctly without overviews, with or without
 -Y.
 >raster2pgsql -t 100x100 -I -C -M bogota.tif  temp.bogota | psql
 OK.
 (drop table)
 >raster2pgsql -t 100x100 -I -C -M -Y bogota.tif  temp.bogota
 OK.
 (drop table)
 >raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif  temp.bogota | psql
 OK.
 (drop table)
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif  temp.bogota | psql
 OK.
 (drop table)
 0c. Trying to add without dropping the table. Messy failure.
 OK.
 ERROR:  current transaction is aborted, commands ignored until end of
 transaction block
 invalid command \.
 ERROR:  syntax error at or near "0100000100622255302"
 LINE 1: 0100000100622255302AA9333F622255302AA933BFA311BC0512A85EC000...
 transaction block
 1. Import with overview 2 and "-Y"
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -l 2 -Y temp.bogota | psql
 OUTPUT
 Processing 1/1: bogota.tif
 CREATE TABLE
 ERROR:  rt_band_from_wkb: Premature end of WKB on band data reading
 (rt_api.c:6611)
 CONTEXT:  COPY o_2_bogota, line 9, column rast:
 "01000001000000000000005E400000000000005EC000000000405D1C4100000000008EF24000000000000000000000000000..."
 2. Import with overview 2 and without "-Y"
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -l 2 temp.bogota | psql
 OUTPUT
 LINE 1: INSERT INTO "temp"."o_2_bogota" ("rast") VALUES ('0100000100...
 (no tables added)
 3. Import with overview 16 and with "-Y"
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -l 16 -Y temp.bogota | psql
 OUTPUT
 ERROR:  unterminated quoted string at or near "'"
 LINE 1: SELECT AddOverviewConstraints('temp','o_16_bogota','
 4. Import with overviews 2 and 16 and with -Y
 >raster2pgsql -t 100x100 -I -C -M bogota.tif -l 2,16 -Y temp.bogota | psql
 OUTPUT
 CREATE TABLE
 ERROR:  rt_raster_from_hexwkb: Raster HEXWKB input must have an even
 number of characters
 CONTEXT:  COPY o_16_bogota, line 1, column rast:
 "01000001000000000000008E400000000000008EC00000000040E61A4100000000006AF84000000000000000000000000000..."
 5. Import with overviews 2,16,32 and with or without -Y
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -Y -l 2,16,1000 temp.bogota
 | psql
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -l 2,16,1000 temp.bogota |
 psql
 OUTPUT:
 CREATE TABLE
 (rt_api.c:6611)
 CONTEXT:  COPY o_32_bogota, line 1, column rast:
 "01000001000000000000009E400000000000009EC00000000040E61A4100000000006AF84000000000000000000000000000..."
 6.  Import with overviews 2,16 and without -Y
 > raster2pgsql -t 100x100 -I -C -M bogota.tif -Y -l 2,16 temp.bogota
 OUTPUT:
 7. Add a tiff, then try again. Bad things happen.
 > raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -Y -l 4 temp.bogota |
 psql sl
 (works)
 psql sl
 (fails horribly)
 ERROR:  relation "bogota" already exists
 transaction block
 transaction block
 invalid command \.
 *** glibc detected *** raster2pgsql: corrupted double-linked list:
 0x0000000001e209a0 ***
 ======= Backtrace: =========
 /lib64/libc.so.6[0x3d15a7c1a2]
 /lib64/libc.so.6[0x3d15a7c988]
 /usr/local/lib/libgdal.so.1(+0x5837c3)[0x7fc5cdba57c3]
 /usr/local/lib/libgdal.so.1(+0x58383f)[0x7fc5cdba583f]
 /usr/local/lib/libgdal.so.1(+0x3485fb)[0x7fc5cd96a5fb]
 /usr/local/lib/libgdal.so.1(_ZN10GDALDriverD1Ev+0x2a)[0x7fc5cdb7264a]
 /usr/local/lib/libgdal.so.1(_ZN10GDALDriverD0Ev+0x9)[0x7fc5cdb72689]
 /usr/local/lib/libgdal.so.1(_ZN17GDALDriverManagerD1Ev+0xd2)[0x7fc5cdb74b62]
 /usr/local/lib/libgdal.so.1(_ZN17GDALDriverManagerD0Ev+0x9)[0x7fc5cdb74c89]
 /usr/local/lib/libgdal.so.1(+0x2a28e2)[0x7fc5cd8c48e2]
 /lib64/ld-linux-x86-64.so.2[0x3d1520f5f7]
 8. Variation in overview scale. A works, B doesn't. (overview 2 vs.
 overview 100)
 A
 > raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -Y -l 1000
 temp.bogota | psql sl
 B
 OUTPUT:
 A
 COMMIT
 VACUUM
 VACUUM
 B
 CONTEXT:  COPY o_100_bogota, line 1, column rast:
 "0100000100B90585EB51B89E3FB90585EB51B89EBFA311BC0512A85EC0000000000000434000000000000000000000000000..."
 9. A closer look at the STDOUT output of:
 >raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -Y -l 100 temp.bogota
 OUTPUT:
 VACUUM ANALYZE "temp"."bogota";
 VACUUM ANALYZE "temp"."o_100_bogota";
 Segmentation fault
 10. Various errors depending on how many times the same overview is
 requested:
 (asking for -2 once)
 >raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -Y -l 2 temp.bogota
 0x00000000025719a0 ***
 /usr/local/lib/libgdal.so.1(+0x5837c3)[0x7fdfbc89b7c3]
 /usr/local/lib/libgdal.so.1(+0x58383f)[0x7fdfbc89b83f]
 /usr/local/lib/libgdal.so.1(+0x3485fb)[0x7fdfbc6605fb]
 /usr/local/lib/libgdal.so.1(_ZN10GDALDriverD1Ev+0x2a)[0x7fdfbc86864a]
 /usr/local/lib/libgdal.so.1(_ZN10GDALDriverD0Ev+0x9)[0x7fdfbc868689]
 /usr/local/lib/libgdal.so.1(_ZN17GDALDriverManagerD1Ev+0xd2)[0x7fdfbc86ab62]
 /usr/local/lib/libgdal.so.1(_ZN17GDALDriverManagerD0Ev+0x9)[0x7fdfbc86ac89]
 /usr/local/lib/libgdal.so.1(+0x2a28e2)[0x7fdfbc5ba8e2]
 11. add another ,2
 >raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -Y -l 2,2 temp.bogota
 OUTPUT:
 SELECT
 AddRasterConstraints('temp','bogota','rast',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,TRUE);
 SELECT
 AddRasterConstraints('temp','o_2_bogota','rast',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,TRUE);
 SELECT
 Segmentation fault
 12. and without -y
 >raster2pgsql -t 100x100 -I -C -M ilatlon_float.tif -l 2,2 temp.bogota
 OUTPUT:
 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'::raster);
 Segmentation fault
 13. Trying to add a non-integer overview level. This is not detected.
 OUTPUT:
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif -l 2.5 temp.bogota
 SELECT
 AddOverviewConstraints('temp','o_2_bogota','rast','temp','bogota','rast',2);
 END;
 VACUUM ANALYZE "temp"."o_2_bogota";
 Segmentation fault
 14. Forgetting to specify the overview factor produces a misleading error
 message
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif -l temp.bogota
 OUTPUT:
 ERROR: Overview factor 0 is not between 2 and 1000
 (should be: Overview factor not specified)
 15. Large numbers uncover another bug. Maybe a BASH bug.
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif -l 100000000000
 temp.bogota
 OUTPUT:
 ERROR: Overview factor 1215752192 is not between 2 and 1000
 16. Specifying -l multiple times causes segfault (without and without
 duplication of overview factor)
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif -l 2 -l 4
 temp.bogota
 >raster2pgsql -t 100x100 -I -C -M -Y ilatlon_float.tif -l 2 -l 2
 temp.bogota
 OUTPUT:
 Segmentation fault
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2359>
