[postgis-tickets] [PostGIS] #2360: [raster]: ST_DumpAsPolygons database engine crash
PostGIS trac at osgeo.org
Thu Jun 13 06:32:17 PDT 2013
 Reporter:  kafka     |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.0
Component:  raster    |     Version:  2.0.x
 Keywords:            |
Comment(by robe):
 actually my 9.2 32-bit version doesn't crash either.  I discovered that
 was because I was using my gcc 4.5 postgis compiled binaries with gcc
 4.8.0 libstd++ dlls I was experimenting with so had a gcc mismatch.  If I
 switch back to my 4.5.4 libstd++ it works fine.
 That said: kafka can you please do a
 SELECT version();
 and return what that is to rule out gcc as difference
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2360#comment:3>
