[postgis-tickets] [PostGIS] #2359: raster2pgsql - large collection of examples of different bugs in -l (overviews)
PostGIS trac at osgeo.org
Thu Jun 13 11:48:28 PDT 2013
(overviews)
  Reporter:  gbell   |       Owner:  dustymugs
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.0.4
 Component:  raster  |     Version:  2.0.x
Resolution:          |    Keywords:  raster2pgsql overviews
Comment(by gbell):
 "If you were to use INSERT statements (no -Y flag), the output looks like
 the following..."
 That may be true, but it is not relevant in any way, since I am not
 submitting a bug report about that other program mode.
 I mean, if you ran menu item 1 in MS Word and it generated junk text, it
 would hardly console you to find out that menu item 2 runs correctly. The
 whole point of the bug report is to highlight bizarre output from an
 execution path through the code.
 It's great to hear INSERT mode works correctly. But it would be even
 better if COPY mode also worked correctly, from a user perspective.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2359#comment:9>
