[postgis-tickets] [PostGIS] #2361: [raster] Add index flag column to raster_columns
PostGIS trac at osgeo.org
Fri Jun 14 16:51:44 PDT 2013
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS Future
Component:  raster       |     Version:  trunk
 Keywords:               |
 Add column to raster_columns view indicating if a raster column has an
 index...
 The following query should be a decent starting point...
 SELECT
         n.nspname AS "schema",
         c2.relname AS "table",
         c.relname AS "index",
         att.attname AS "column"
 FROM pg_catalog.pg_class c
 JOIN pg_catalog.pg_index i
         ON i.indexrelid = c.oid
 JOIN pg_catalog.pg_class c2
         ON i.indrelid = c2.oid
 JOIN pg_catalog.pg_namespace n
         ON n.oid = c.relnamespace
 JOIN pg_am am
         ON c.relam = am.oid
 JOIN pg_attribute att
         ON att.attrelid = c2.oid
                 AND pg_catalog.format_type(att.atttypid, att.atttypmod) =
 'raster'
 WHERE c.relkind IN ('i')
         AND n.nspname NOT IN ('pg_catalog', 'pg_toast')
         AND n.nspname = 'tops'
         AND am.amname = 'gist'
         AND strpos(split_part(pg_catalog.pg_get_indexdef(i.indexrelid, 0,
 true), ' gist ', 2), att.attname) > 0
 ORDER BY 1,2,3;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2361>
