[postgis-tickets] [PostGIS] #2363: st_distance with an added Integer value is not working in 2.0
trac at osgeo.org
Mon Jun 17 12:42:29 PDT 2013
Reporter: vbalent | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
Val,
Minor suggestion, you should be using ST_DWithin(geom1,geom2,5280) instead
of sT_Distance because ST_Distance will never use an index.
That aside these issues are often caused by missing nadgrid files. An
easy verification:
SELECT ST_AsText(ST_Transform(ST_POINTFROMTEXT('POINT(-73.76545859999999
42.658618)', 4326), 2260));
on both systems and verify they return the same answer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2363#comment:1>
